Date/Time: Wed, 27 Nov 2024 18:52:05 +0000
MACD & SIGNAL Line
View Count: 1087
[2014-10-01 17:33:30] |
User22591 - Posts: 133 |
Good day Support Board! Do we have an alert formula for MACD and its signal line crossing above or below "0"? If we do may I have it? Thanks Date Time Of Last Edit: 2014-10-02 05:37:03
[2014-10-01 21:57:37] |
Sawtooth - Posts: 4120 |
Refer to the documentation: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Scroll down for some examples. |
[2014-10-03 00:29:32] |
This is example number 24 here: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#examples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
