Date/Time: Mon, 16 Sep 2024 19:08:01 +0000
Sim trade management behavior
View Count: 932
[2014-10-01 15:44:24] |
User3847 - Posts: 8 |
I noticed that in sim trading when I open a position, and then change the chart to another instrument, the trade will not be managed for the changed instrument anymore. Is there away to have it monitor the sim trade (stops/targets) for it in the background?
[2014-10-01 17:20:31] |
No. You do need to have the same chart where the orders were entered from, open and set to the same symbol.
