Date/Time: Thu, 28 Nov 2024 00:23:03 +0000
[Locked] - Stock names
View Count: 1103
[2014-10-01 15:43:23] |
User3847 - Posts: 8 |
In the QuoteBoard I can enter the stock ticker symbols but the Name column is blank. Whereas for futures the name is populated with the contract name. How do I get the stock company name to show up? I'm using the paid Sierra Chart Real-Time and Historical Exchange Data Feed if that matters.
[2014-10-01 16:23:31] |
We are looking into this, but the stock name may not be available.
[2014-10-01 17:06:16] |
We checked. The stock names are not available.
[2014-10-02 02:18:56] |
Any plans on adding names in the future? It seems like a fairly basic feature for a stock feed to show the stock names. Thanks
[2014-10-02 02:52:18] |
The problem is the source data feed we have does not have the names. We will find out about this.
[2014-10-27 18:47:17] |
User85468 - Posts: 9 |
I too cannot find any tickers whatsoever for my stocks in Chart Settings (F5). I use IB. They are available on my IB platform. Do you have a solution now please?
[2014-10-27 23:38:31] |
Refer to this page: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html You can find symbols through File >> Find Symbol. Stocks are not listed and have to be manually entered. This thread is being closed. This should have been started as a new Support Request. It is unrelated to this one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
