Date/Time: Wed, 27 Nov 2024 18:48:11 +0000
Drawings/Studies & Price Bar Transparency/Opacity
View Count: 1219
[2014-10-01 11:17:44] |
User78442 - Posts: 260 |
Hi SC, is there a quick way to change various Transparencies/opacity of chart/study elements i.e. their order on the charts - I especially want price bars to override any other study/drawing element. Many thanks, James
[2014-10-01 17:05:48] |
You can set a study to be drawn underneath the main price graph. Refer to this setting in Study Settings: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DisplayStudyUnderMPG Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
