Date/Time: Mon, 16 Sep 2024 19:06:53 +0000
changed symbols, studies won't display
View Count: 870
[2014-10-01 09:35:34] |
jivetrader - Posts: 400 |
changed futures symbol from TY to NQ (and session times as appropriate), now some studies like Initial Balance, Daily OHLC do not display. please advise
[2014-10-01 09:54:24] |
You need to understand that we cannot help with questions worded in this way. You will need to provide us a Chartbook that contains a single chart and contains a single study, and no other studies, which demonstrate the issue so that we can look at it. In general, you will need to check the settings of the studies to make sure they are all correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
