Date/Time: Sat, 23 Nov 2024 08:02:52 +0000
[User Discussion] - I need help creating a footprint chart (with an example image)
View Count: 82
[2024-11-20 11:42:41] |
natngk - Posts: 16 |
I want to create a footprint chart that looks like the one in the image. Can anyone guide me?
Private File |
[2024-11-20 11:59:42] |
User431178 - Posts: 540 |
If you make the image public instead of private, you might have more chance of getting help.
[2024-11-20 12:05:32] |
How can I make it public?
[2024-11-20 16:47:07] |
Refer to the following, specifically step #7: Support Board Posting Information: Attaching a File (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-21 12:52:13] |
this. is a sample image.
2. Order Flow Intro - Footprint Chart Basics.tiff - Attached On 2024-11-21 12:50:54 UTC - Size: 103.08 KB - 13 views Attachment Deleted. |
