Date/Time: Sat, 23 Nov 2024 09:44:01 +0000
T&S
View Count: 82
[2024-11-19 23:54:43]
User789748 - Posts: 3
Hi there,
I'm new with Sierra.
Trying opening T&S alone, but it looks like it only works with DOM conjunction.
If I'm wrong, than correct me please.
Otherwise, why T&S couldn't be opened alone like with other software's I've used before?
Thank you,
Stella
[2024-11-19 23:56:38]
Make sure you are selecting "File >> Open Time and Sales Window".
Refer to the following:
[2024-11-20 01:20:16]
I do that, but if I don't have a DOM/Chart open and get to "File >> Open Time and Sales Window" than that option is grayed out.
Or if a Dom and T&S for it are opened, and I wish to open a different T&S for another security without having a DOM/Chart for that security than it won't do it.
[2024-11-20 16:20:38]
Yes, you do need to have a Chart/DOM open in order to open the Time and Sales window for a particular instrument.
[2024-11-21 19:53:41]
Thx.
Though would be nice to have an ability for additional T&S's without overloading the system resources with unnecessary Chart/DOM's.
Also would be great for a DOM's target ATM to have choices as:
1. "Reverse at Stop" with *Any or *Stop Loss Only options (Any - includes Trailing, Breakeven & Stop Loss);
2. "Reverse at Target"
Does a single DOM have an ability to Tab multiple instruments?
Thank you,
Stella
[2024-11-21 20:16:43]
You can always hide the charts after opening the Time and Sales window to cut down on the resources.
You should look into using the Spreadsheet System for Trading in order to get reversals when you want. Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
Yes, a Trading DOM is just a specialized chart. So you can change the symbol using any of the methods at the following link:
Changing the Symbol of a Chart
