Date/Time: Sat, 23 Nov 2024 08:24:29 +0000
support and resistance on mac d study
View Count: 31
[2024-11-18 22:38:32] |
SafSaf - Posts: 89 |
alright lads, is there a study which allows me to add a line showing the highest high of the mac d, and another line showing the lowest low .... and at the same time allowing me to choose a period, say 50 bars, for the lines to move when the highs and lows change to match the highest high and lowest low of the mac d and change as it moves forward to represent the past 50 bars? tia
[2024-11-18 22:40:11] |
Use the "Highest High / Lowest Low over N Bars" study for this and set the "Based On" to be the "MACD" study. Refer to the following: Highest High/Lowest Low Over N Bars Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
