Date/Time: Sat, 23 Nov 2024 09:27:12 +0000
Modifying Child orders doesn't show change in points until you let go of the mouse button
View Count: 36
[2024-11-18 17:21:44]
cuckiecheese - Posts: 61
I recently updated to version 2700, prior to this, I was on 2679. When you place bracketed orders, usually when you drag the child orders, it shows the distance in points changing while you're dragging/modifying, however, in 2700, the changes aren't reflected until you let go of the mouse button to stop dragging.
[2024-11-18 20:37:20]
Check the setting for "Trade >> Chart Trade Settings >> Working Orders >> Attached Order P/L when Modifying". This needs to be set to "Yes" for the P/L to update on a working order line while you are moving it. Refer to the following:
Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display)
There has not been any change to this, so we do not know why you would be seeing any difference in the release.
[2024-11-18 20:42:03]
Thank you, that fixed it, not sure why it got turned off
