Date/Time: Sat, 23 Nov 2024 09:27:11 +0000
Is there an actual
View Count: 60
[2024-11-18 15:16:39]
User429065 - Posts: 118
See attached... I like how the "Combined Bid/Ask Market Depth Pulling/Stacking" within the DOM tends to lead price. How can these Pulling/Stacking (white) Numbers appear outside the DOM closer to price?
Also, is there an actual study representing this "Combined Bid/Ask Market Depth Pulling/Stacking" result?
I don't mind building this from any combination of studies if I can find at least the initial study of this result.
Thank you!
Date Time Of Last Edit: 2024-11-18 16:53:59
imagePS BA for Support.JPG / V - Attached On 2024-11-18 14:23:58 UTC - Size: 21.23 KB - 19 views
[2024-11-18 17:56:31]
Those are the sum of the Pulling/Stacking columns. This is available in the "Numbers Bars Calculated Values 2" study. You can then reference that study in any way you want to use those values. Refer to the following:
Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions
[2024-11-18 18:55:29]
Is there yet a way to retain any of this data even after refreshing a chart? Even just a designated amount such as 15 columns/bars would make a huge opportunity out of this valuable data.
Date Time Of Last Edit: 2024-11-18 19:24:52
[2024-11-18 21:40:18]
There is not a way to retain the data. You can run a replay in order to get the data recalculated and hence show up again, but that is the only option.
