Date/Time: Sat, 23 Nov 2024 09:28:47 +0000
How to accurately set up cumulative adjusted value for TICK-SP
View Count: 133
[2024-11-15 18:06:08]
BigBagel - Posts: 58
Basically the title. Do I add the cumulative adjusted value study to a chart of TICK-SP and pull it over using study/price overlay study?
Date Time Of Last Edit: 2024-11-15 18:53:42
[2024-11-15 19:50:45]
You add the "Cumulative Adjusted Value" study to the TICK-SP chart and you will get the Cumulative Adjusted Value for the "OHLC Average" in a separate region on that chart. Refer to the following:
Chart Studies: Adding/Modifying Chart Studies
If you do not want to use the OHLC Average, then change the Input for "Input Data" on the Cumulative Adjusted Value study. Refer to the following:
If you want to view the Cumulative Adjusted Value as the main graph, then set to the option for "Display As Main Price Graph" on the Settings page for the study. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph
[2024-11-15 19:56:38]
Ok. So when I have it setup on the TICK-SP chart, I use the "Study/Price Overlay" to bring it over to my main chart correct?
[2024-11-15 20:18:01]
If you want it displayed in a separate region on your "Main Chart" then yes, the "Study/Price Overlay" is the way to do that. Refer to the following:
Study/Price Overlay Study
[2024-11-16 23:14:27]
Sierra_Chart Engineering - Posts: 17145
No specific way. However works best for you.
Date Time Of Last Edit: 2024-11-16 23:14:35
[2024-11-16 23:46:12]
Ok so if I want to set it up like the article. Use the cumulative adjust line on the TICK-NYSE 1 min chart, and change the smoothing to 7800
[2024-11-18 14:54:37]
Yes, if that is what you want. We really can not say what is best, it depends on what you want to see from it.
[2024-11-18 15:00:52]
I want to set it up the same as the article you guys posted under the "Explanation of Tick Positive or Negative Bias and How to correct". I was assuming it was the cumulative adjust value on a 1 minute chart of TICK-NYSE, and a smoothing value of 7800
Date Time Of Last Edit: 2024-11-18 15:02:11
[2024-11-18 15:06:32]
Then yes, that is what you should do.
