Date/Time: Sat, 23 Nov 2024 08:20:27 +0000
Customize Trade DOM Column
View Count: 44
[2024-11-15 03:29:54]
User377189 - Posts: 172
When i try to add columns to trade DOM, under customize trade DOM column.
Instead of adding a column, an existing column from DOM is being replaced
I have attached a video showing this.
Private File
[2024-11-15 15:01:05]
There are a few columns that are exclusive to each other. The "Cumulative Last Size" and "Last Size" are two of these columns. You can not have both displayed at the same time, it is either one or the other.
The "Bid Size/Buy Column" and "Buy Order Column" and "Bid Size" (along with the corresponding Ask columns) are others that are similar in this manner.
