Date/Time: Sat, 23 Nov 2024 09:36:28 +0000
Option
View Count: 56
[2024-11-14 17:29:11] |
Deltareversal - Posts: 45 |
I would like to add Option "OI" levels to the chart (I have the data in .txt format), similar to the attached image (photoshopped example). I was considering using the spreadsheet function—would this be feasible? Alternatively, could you provide some instructions on how to overlay these levels on the chart? |
Chart + Option Level.png / V - Attached On 2024-11-14 17:29:01 UTC - Size: 88.95 KB - 21 views |
[2024-11-14 17:30:49] |
The only way to do something like that would be through a custom study. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
