Date/Time: Sat, 23 Nov 2024 09:37:39 +0000
drawing tools saved names
View Count: 84
[2024-11-13 20:20:52] |
User374714 - Posts: 4 |
Hi! I have saved the drawing tools with a name. But under the right mouse button the configuration names I saved are not available. |
rechte maustaste.png / V - Attached On 2024-11-13 20:20:45 UTC - Size: 35.83 KB - 14 views |
[2024-11-13 20:29:18] |
The reason for this is that you have set a custom menu option for those configurations, therefore that is overriding the actual Configuration Names that are set within the configurations. If you remove those customized menu options for the tool configurations, then you will get the configuration names instead.
[2024-11-13 20:35:03] |
ok, how do I get there?
[2024-11-13 20:48:06] |
Global Settings >> Customize Menu Items. On the left will be a section for "Chart Drawing Context Menu". Find the entries for the configurations (Config 1, Config 2, etc.) and remove the customized names for those items. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-13 20:59:04] |
All clear, thank you
