Date/Time: Sat, 23 Nov 2024 08:24:05 +0000
Custom Study
View Count: 80
[2024-11-11 23:59:37]
User558380 - Posts: 36
Hi! I tried building a custom study (in remote) and have not seen the study added anywhere. I've looked under Analysis - Studies - Add Custom Study but do not see it listed. I also haven't seen any error messages. Is there a way you can check on this for me? I'm sure I'm just doing something wrong. Let me know what information I need to provide you. Thanks so much.
[2024-11-12 15:32:39]
If the program compiled correctly then the .dll file will be in your 'Data' folder. Check to see if there is a file that has the same name as your .cpp file but with the extension of .dll in the 'Data' folder.
If the file is there and you are not able to find it when trying to add the study, then you would need to look at your "Message Log" to see what it shows in relation to that file.
IF the file is not there, then there was some problem with compiling the .cpp file. You would need to redo the remote compile and look at the information in the "Build Output" section of the "Build Advanced Custom Studies" window. You can resize that window if the Build Output is not easily readable.
[2024-11-13 12:59:34]
Thanks so much. I did not see the study in my data folder. I will try the remote build again and will get back to you either way. Thanks, again.
[2024-11-13 13:23:12]
Hello, again. I was able to perform the remote build again and my study is there. All is good. Thanks so very much.
