Date/Time: Sat, 23 Nov 2024 09:29:55 +0000
Change Quantity not highlighting value (select all) after new update
View Count: 40
[2024-11-11 15:14:50]
TonyCipriani - Posts: 18
For the past year or so when I was using Sierra Chart with 'Chart Trade Mode On' enabled, I would be able to press the Change Quantity field, and the value would be highlighted (select all). I updated the software recently, and now when I go to change the quantity, it's not highlighting. I enter with different quantities for each position, and when it was highlighting, I would be able to type any quantity quickly to have it changed. For instance, if I entered with 4 contracts before and I pressed Change Quantity, I would be able to quickly type 8 and it would change to 8. Without the highlighting, when pressing Change Quantity and wanting to enter with 8 contracts, it gives 84.
Thanks a lot for your help.
[2024-11-11 16:27:33]
Set the following setting to "Yes" to get this to work as you want:
General Settings Window: Select All Text in Edit Control Upon Editing (Global Settings >> General Settings >> SettingsWindows)
