Date/Time: Sat, 23 Nov 2024 08:03:02 +0000
Auto-Trading by spreadsheet only open 1 contract size and how to open limit order?
View Count: 59
[2024-11-11 14:12:30] |
User515613 - Posts: 10 |
Hi Sierra Chart support, I have setup spreadsheet for trading to open trade but it only open 1 contract size while I used attached order and clicked on 2 contract size. Please refer to attached screenshot for your reference and let me know what I missed? Further to this, how can I setup spreadsheet for trading to open buy limit at lowest closed of previous hour and open sell limit at highest closed of pervious hour? I can't find any detail on this from documentations. Hope you can assist. Thanks and regards, Ken B |
2024-11-11 Spreadsheet contract size issue 1.jpg / V - Attached On 2024-11-11 14:12:11 UTC - Size: 510.69 KB - 12 views |
[2024-11-11 16:24:57] |
If you have specified a quantity in the J column cell for "Order Quantity" then this will override the quantity that is set in the Trade Window. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Order Quantity [J26] To open a Buy Limit or Sell Limit you need to set the J column cell for "Buy Entry: Order Type" and/or "Sell Entry" Order Type" to be "L" for Limit (or "SL" for Stop Limit) and then set the J column cell for "Limit or Stop Price - Buy Entry" and/or "Limit or Stop Price - Sell Entry" to be the Limit price you want. You can enter a formula in these cells to get the previous hour's Lowest and Highest values. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Buy Entry: Order Type [J71] Spreadsheet Systems, Alerts and Automated Trading: Limit or Stop Prices [J22, J23, J24, J25] Spreadsheet Functions: Serial DateTime Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-12 01:53:18] |
Thank you so much John. It solved my issues.
