Date/Time: Sat, 23 Nov 2024 09:32:23 +0000
New timer method - Number Bars Chart
View Count: 231
[2024-11-09 06:03:54] |
methodtrades - Posts: 46 |
Been adjusting everything for optimal performance on 2702 with the new timers method. Overall I like the rigidity of how this works. One issue I've personally run across is on a numbers bars chart. If I zoom out, to 5+ days, the chart hangs with max processor core usage. Have a couple studies on it, but nothing major. Numbers bars, calculated values tables, cumulative delta bars, and that's it.
Date Time Of Last Edit: 2024-11-09 06:08:05
[2024-11-09 22:39:33] |
Sierra_Chart Engineering - Posts: 17145 |
This is definitively not related to timers. That is completely impossible. It is something completely unrelated. Maybe it is related to OpenGL. Try disabling OpenGL: Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other) Or it could be related to what is explained here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-09 22:39:40
[2024-11-10 01:32:11] |
Thanks. Will look into other causes. However, if the update interval in the chart settings is set to something like 5000, it doesn't freeze SierraChart when zooming out. However if it's set to a lower interval such as 30, it does.
[2024-11-10 18:48:20] |
In this case, it sounds like the chart is continuously being drawn for some reason. You can see if that is the case, by selecting Chart >> Chart Settings >> Performance. When the market is closed, Average Calculation and Draw Time should remain at 0 ms. If it does not, it is being drawn for unknown reasons. So that problem has to be determined. And when the Numbers Bars are very dense, there is a lot of draw time. Increase the Tick Size to change that: Numbers Bars: Adjusting Tick Size For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-10 18:48:32
[2024-11-10 20:15:38] |
We have to make a change to how the Average Calculation and Draw Time is implemented because if a chart is not actually updating, it can still show prior values and be misleading. The change has been made and will be out tomorrow. One thing that can cause a chart to continuously update is the Countdown Timer when it is set to display a countdown based on the real-time clock. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-10 21:12:09
[2024-11-22 04:34:03] |
Your last messages were quite helpful. I isolated the issue of freezing. The chart still lags, as I would assume, when zooming out, but does not freeze any longer. It turns out the average calculation and draw time metric was still greater than 1 in no market activity states due to the setting: Chart Settings > Market Depth > Draw DOM graph on chart - being set to "Yes". Setting this to no reverts the draw time to the expected zero and solves the crash scenario. Thank you |
[2024-11-22 17:40:31] |
We will work on making that market depth graph more efficient.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-22 17:41:01
