Date/Time: Sat, 23 Nov 2024 09:32:12 +0000
Connection limit exceeded.
View Count: 152
[2024-11-08 03:49:57]
User130696 - Posts: 88
Why I am receiving this error ? I am using Denali on only one device.
2024-11-07 22:43:35.991 | External Service | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
I can see that my account has 3 systems.
Allowed Systems:  2 out of a total of 3 system(s) are currently being used.
[2024-11-08 14:42:19]
We see two different computers both connected at the same time, and both are showing the same IP address, therefore they are within the same network environment (i.e. they are both at your house or workplace).
You need to exit from Sierra Chart on the system that you are not actively using.
[2024-11-12 21:48:41]
I am absolutely not trying to get connected two times using same broker from same IP address or not running extra connection before attempting new connection.
Please investigate it further and in short term how to kill orphan connection if this is a false signal?
[2024-11-13 02:02:18]
Sierra_Chart Engineering - Posts: 17145
There is no doubt, that you are connecting to the Denali Data Feed from more than one computer at the same time. We see you are using two computers at times.
We could invalidate a particular instance of Sierra Chart. But it takes a while for that to go into effect. It could take up to 24 hours.
Date Time Of Last Edit: 2024-11-13 02:02:59
[2024-11-14 23:39:12]
2024-11-14 18:37:23.030 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:23.030 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:23.070 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:23.070 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:23.081 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:23.081 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:23.081 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:23.081 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:23.081 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:23.081 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:23.123 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:23.123 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:23.123 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:23.123 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3842
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:23.249 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:23.249 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:23.249 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:23.290 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:23.290 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:23.312 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:23.312 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:23.312 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:23.312 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:23.312 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:23.312 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:23.355 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:23.355 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:23.355 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:23.355 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3843
2024-11-14 18:37:23.491 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:23.492 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:23.492 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:23.492 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:23.492 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:23.534 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:23.534 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:23.619 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:23.619 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:23.619 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:23.619 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:23.619 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:23.619 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:23.667 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:23.667 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:23.667 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:23.667 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3844
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:23.805 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:23.805 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:23.805 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:23.846 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:23.846 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:23.868 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:23.868 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:23.868 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:23.868 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:23.868 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:23.868 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:23.920 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:23.920 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:23.920 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:23.920 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3845
2024-11-14 18:37:24.067 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:24.068 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:24.068 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:24.068 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:24.068 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:24.109 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:24.109 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:24.121 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:24.121 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:24.121 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:24.121 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:24.121 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:24.121 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:24.183 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:24.183 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:24.183 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:24.183 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3846
2024-11-14 18:37:24.315 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:24.316 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:24.316 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:24.316 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:24.316 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:24.357 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:24.357 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:24.414 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-11-14 18:37:24.414 | External Service | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-11-14 18:37:24.414 | External Service | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50509
2024-11-14 18:37:24.415 | Network | DTC Client socket (4) | Creating socket. Using TLS 1.2.
2024-11-14 18:37:24.415 | Network | DTC Client socket (4) | New receive buffer size: 0
2024-11-14 18:37:24.415 | Network | DTC Client socket (4) | Connecting to IP: 216.57.156.163.
2024-11-14 18:37:24.479 | External Service | Rithmic Direct - DTC (Data) | Network connection to server complete.
2024-11-14 18:37:24.479 | External Service | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2024-11-14 18:37:24.479 | External Service | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2024-11-14 18:37:24.479 | External Service | Rithmic Direct - DTC (Data) | Sending logon request message.
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Received logon response.
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Server Name: .
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Logon error received from server: permission denied
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Failed connections: 3847
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end
2024-11-14 18:37:24.626 | Network | DTC Client socket (4) | CloseSocket call.
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Disconnected from the server.
2024-11-14 18:37:24.626 | External Service | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 0 seconds.
2024-11-14 18:37:24.626 | Network | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-11-14 18:37:24.667 | Network | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-11-14 18:37:24.667 | Network | DTC Client socket (4) | Closed.
2024-11-14 18:37:24.760 | External Service | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
Date Time Of Last Edit: 2024-11-15 01:29:59
[2024-11-15 00:06:43]
Also, please check and confirm trade activity log about why is this happening each time for last one week ?
attachmentTradeActivityLogExport_2024-11-15.txt - Attached On 2024-11-15 00:06:09 UTC - Size: 1.37 MB - 18 views
[2024-11-15 01:32:00]
Regarding post #5, do the following:
Select Global Settings >> Data/Trade Service Settings >> Main Settings.
Completely clear the following:
market data username
market data password
historical data username
historical data password
Press OK.
What is the issue with trading that you are having. If there is no trading issue the Trade Activity Log is not relevant.
Date Time Of Last Edit: 2024-11-15 01:32:55
[2024-11-15 01:35:34]
It kept on closing the order at market rate even if account balance was ok. And it kept disconnecting.
[2024-11-15 03:51:45]
The disconnecting issue should be resolved, with the change we said to do.
Regarding the issue with the particular order we need to see the very specific Trade Activity Log lines for that order only. Instructions:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
