Date/Time: Sat, 23 Nov 2024 08:06:52 +0000
DOM Recent Bid and Recent Ask clear
View Count: 86
[2024-11-07 19:55:24]
preetbanwait - Posts: 12
How do I set the settings for trading DOM to clear the recent bid and ask to clear it even though the price has not been tested again? Yes, it will clear the price when the price is trading at those which I have set to 2500 ms. Please check the attached file and marked boxes for better understanding.
imageScreenshot 2024-11-07 144633.png / V - Attached On 2024-11-07 19:54:23 UTC - Size: 144.14 KB - 23 views
[2024-11-07 20:59:46]
There is no option for clearing the Recent Bid/Ask data when the price has not returned to a price level after a certain amount of time.
[2024-11-11 18:37:59]
Hi John, I have found a way to clear it. When right-clicking the mouse in the recent bid/ask column. There is an option to clear it. Can I add the hotkey to it, I was looking in the shortcut key options but could not find anything yet.
Please check the attachment
imageScreenshot 2024-11-11 133324.png / V - Attached On 2024-11-11 18:37:51 UTC - Size: 121.95 KB - 14 views
[2024-11-11 20:45:57]
There are multiple ways to clear the entire Recent Bid/Ask columns. We did not think that was what you were looking for. To start with, there is a menu option for "Trade >> Clear Recent Bid/Ask Volume". There is also a default keyboard shortcut of "Alt-N" associated with this. You can change it in "Customize Keyboard Shortcuts".
There are also Control Bar button options for "Clear Current Bid/Ask" and "Clear Current Bid/Ask - All Symbols".
