Date/Time: Sat, 23 Nov 2024 08:03:55 +0000
heatmap
View Count: 212
[2024-11-05 20:48:01] |
User496868 - Posts: 18 |
i tried creating a heatmap like this photo but when i tried the market deapth historical graph columns didnt look transpernt and the large volume trade indicator didnt apper and the market deapth historical graph only start when i enter the softwear unlike the guy in the video i added his heatmap and mine |
his heatmap.png / V - Attached On 2024-11-05 20:46:49 UTC - Size: 870.05 KB - 75 views Attachment Deleted. |
[2024-11-06 00:23:51] |
One difference between your Market Depth Historical Graphs is that "theirs" uses a lot more levels, whereas yours is limited. Refer to the following Input: Market Depth Historical Graph: Maximum Levels to Display (0 for All) We do not know what you mean about "Transparency". There is no transparency option for the Market Depth Historical Depth study. Having such an option would make the system impossible to use. The Market Depth Historical Graph is a complex study and requires understanding on how it functions in order to get it setup for what you want. Refer to the general information for this study at the following link: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-06 06:23:11] |
What about the lqrge volume trade indicator its not showing
[2024-11-06 16:00:27] |
Typically if the Large Volume Trade Indicator is not showing, it means that you are not storing your data at every tick. You need to have the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit" to be "1 Tick". Refer to the following: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-07 21:33:27] |
i tried it still isnt showing
[2024-11-07 22:03:42] |
Was your "Intraday Storage Time Unit" set to "1 Tick" previously, or did you have to change it? If you changed it, did you redownload all the data for the chart by selecting "Edit >> Delete All Data and Download" once for each symbol? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-09 18:15:00] |
it wasnt on i did delete and it didnt show
[2024-11-09 23:33:34] |
Sierra_Chart Engineering - Posts: 17145 |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
