Date/Time: Sat, 23 Nov 2024 09:26:29 +0000
Small Caps / Penny Stocks
View Count: 180
[2024-11-05 20:03:46]
Tin43 - Posts: 90
Hi, is there a way to see this kind of stocks?
I'm new to this type of trading. Do i have to switch to another package, data feed etc?
Is there a step by step guide?
thanks in advance!
Edit: I'm talking about sim trading.
Date Time Of Last Edit: 2024-11-05 20:05:57
[2024-11-05 23:35:17]
What is the ticker for one stock for which you are looking for data?
[2024-11-06 11:46:33]
Tin43 - Posts: 90
Mm new to small caps...
but this will depend on each stock?
I don't know, to say one TVGN.
[2024-11-06 16:33:03]
It will depend on where the stock is traded. We do not have data for "Over The Counter" (OTC) stocks, but if the stock is traded on a major exchange, then we will have the data.
TVGN, for instance, is available as it is traded on the NASDAQ.
To get the data for U.S. Stocks, you will need to setup the "U.S. Equities Consolidated Tape" exchange by following the instructions at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
Note that the only broker we work with for trading of U.S. Stocks is Interactive Brokers. Refer to the information here:
Interactive Brokers Trading Service
[2024-11-06 21:55:55]
Tin43 - Posts: 90
Sorry I change my data feed to Denali, etc. And activate package 10.
Now when I goto to find symbol:
US Equities-Consolidated Tape (Delayed/Realtaime)
(Enter Search Text - NYSE/AMEX/NASDAQ)
AAPL / Apple Inc.
Is the only one stock that appears.
And the other fiels US Equities.. bla bla with Depht the same except no AAPL.
How do I search other stocks?
[2024-11-07 14:55:00]
You can use any stock symbol. Follow the instructions here to search for them:
File Menu: Searching for Stock Symbols
[2024-11-08 23:38:32]
Tin43 - Posts: 90
Got another doubt.
AZI-NQTV [M] on Sierra Chart is showing me till 11/07/2024 at price 1,63 closing price.
Same symbol on Trading View is showing me till date 11/08/2024 at price 2,53 closing price.
Why?
[2024-11-09 23:19:08]
Sierra_Chart Engineering - Posts: 17145
That is not what we see. This is what we currently see:
https://www.sierrachart.com/image.php?Image=173119386389.png
Refer to:
Date Time Of Last Edit: 2024-11-09 23:20:21
[2024-11-09 23:54:27]
Tin43 - Posts: 90
Don't know why but NOW i'm seeing the same as you and in TradingView.
Don't know what happened or what i touched.
Thanks as always.
