Date/Time: Sat, 23 Nov 2024 22:14:23 +0000
Issue between TPO and trigger Chart
View Count: 74
[2024-11-04 21:47:13]
davidborr - Posts: 1
Good morning,
I have a problem with the TPO and the trigger chart in the ES product.
The problem is that in the TPO chart I have a pVA which the max zone (pVAH) is set at 5780, however, in the execution chart, I get the pVAH at 5804.
There is a very big difference, and I do not understand why it happens. I have tried chartbooks from colleagues that work for them and not for me. I have reinstalled the program, and I still have the same problem.
I have attached two images of what is happening.
Any solution?
Thank you very much for your help.
image1.jpg / V - Attached On 2024-11-04 21:46:55 UTC - Size: 69.83 KB - 18 views
image2.jpg / V - Attached On 2024-11-04 21:47:08 UTC - Size: 209.46 KB - 20 views
[2024-11-05 15:26:28]
Sierra_Chart Engineering - Posts: 17154
Refer to:
Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values
Also refer to:
Time Price Opportunity (TPO) Profile Charts: Resolving Differences Between TPO Profile Charts
