Date/Time: Sat, 23 Nov 2024 23:11:35 +0000
entering order on dom not working
View Count: 47
[2024-11-04 18:23:35] |
coachted - Posts: 328 |
When i enter my order via a dom it is not working but if i use the trade window the order works can you please help me
[2024-11-05 16:43:49] |
What DOM are you using - a Trading DOM or the Chart DOM? Is the Trade Window you are using associated with the same Trade/Chart DOM on which the orders are not able to be placed? What method are you using to place an order on the Trade/Chart DOM? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
