Date/Time: Sat, 23 Nov 2024 09:30:14 +0000
[User Discussion] - Incorrect price when uploading to tradezella
View Count: 166
[2024-10-08 14:51:24] |
User706091 - Posts: 4 |
For some reason when I upload the txt file to tradezella it is showing the wrong number For example I made 444$ but instead Tradezella said that it was 44,400 |
[2024-11-02 21:35:30] |
User818481 - Posts: 4 |
Did this ever get figured out? I'm having the same issue with futures contracts coming over shares which makes the values incorrect.
[2024-11-10 18:31:37] |
Doesnt look like we got a response.
[2024-11-10 18:32:47] |
Can someone from Sierra Charts please respond
[2024-11-10 18:51:56] |
Sierra_Chart Engineering - Posts: 17145 |
In this case, rather than using the Export function of the Trade Activity Log, use File >> Save Log As: Trade Activity Log: Saving to a Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-10 18:52:10
