Date/Time: Sat, 23 Nov 2024 08:31:39 +0000
delayed data
View Count: 124
[2024-09-02 13:13:57]
User449379 - Posts: 3
I have a serious problem- I started using Sierra today after 2 months of a break and it doesn't work properly. The data is delayed or- to be more precise- it doesn't move on at all.
When I turned on Sierra at 2.45, i.e. and hour ago, the platform has been displaying the data until 2.45 and that's it- no new bars appear, nothing, as if the data flow were frozen..
Can you, please, tell me what I should do to make it work again?
I have checked my payments and everything seems to be fine- I have paid for Sierrra as well as for Denali data.
Thank you in advance for your support.
Best regards,
Aleksandra Hortecka-Pietrzak
[2024-09-02 13:49:10]
Sierra_Chart Engineering - Posts: 17145
You are running an older version of Sierra Chart. Update to the current version:
Do you need real-time data? If so let us know for what exchanges. You do not have any exchanges active for real-time data. You can do this here:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed
Date Time Of Last Edit: 2024-09-02 13:49:48
