Date/Time: Sat, 23 Nov 2024 08:28:15 +0000
My Order Fills are not showing on another chart(same symbol, Show Order Fills enabled)
View Count: 98
[2024-09-02 00:49:05] |
pennydoll9 - Posts: 20 |
My Order Fills are not showing on another chart(same symbol, Show Order Fills enabled) within the same chartbook
[2024-09-02 14:02:56] |
Sierra_Chart Engineering - Posts: 17145 |
Refer to all of the information here regarding this: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
