Date/Time: Sat, 23 Nov 2024 08:45:21 +0000
[Programming Help] - sc.UseTool and Line not drawing properly with 1-150 X axis values
View Count: 270
[2024-08-31 17:26:01]
User719512 - Posts: 262
See attached images.
with 75 as anchor 2 of line properties, line ends at 50% or halfway of the window.
with 150 as anchor 2 of line properties, line extends only to last bar and not the right side of the window.
The real use case here is to use sc.UseTool for Tool.DrawingType = DRAWING_LINE; to accomplish the same thing (line all the way across).
When drawn from code, the same behavior is observed.
Please advise, thanks.
imageScreenshot 2024-08-31 101147.png / V - Attached On 2024-08-31 17:25:03 UTC - Size: 83.29 KB - 51 views
imageScreenshot 2024-08-31 101214.png / V - Attached On 2024-08-31 17:25:13 UTC - Size: 84.66 KB - 49 views
[2024-08-31 17:55:42]
DarkNature - Posts: 1
From my observation that happens only if UseRelativeVerticalValues is disabled. By setting it to 1 the anchor of 150 goes to the end of the chart.
But unfortunately I believe that makes it not possible to draw a line at absolute values like a price and use relative horizontal values at the same time properly.
Thanks in advance for your support.
[2024-08-31 17:59:33]
seandunaway - Posts: 268
the docs have a note about drawing into the fill space with EndDateTime or EndIndex
Using Drawing Tools From an Advanced Custom Study: s_UseTool::EndDateTime
[2024-08-31 18:05:27]
you might also try a different drawing type if you're just looking for a full width price level or similar
Using Drawing Tools From an Advanced Custom Study: s_UseTool::DrawingType
Date Time Of Last Edit: 2024-08-31 18:06:41
[2024-08-31 18:26:32]
User431178 - Posts: 540
They do, but that is not relevant if you are using relative positioning. The purpose being to position drawings in fixed location via coordinate system, not tied to a bar index or real datetime.
Seems something is broken.
Or maybe some drawing tools don't play nice with relative positioning?
Date Time Of Last Edit: 2024-08-31 18:29:23
[2024-08-31 22:57:39]
Sierra_Chart Engineering - Posts: 17145
We do not see any problem with this. There definitely is nothing in the code, which positions, a Chart Drawing with consideration to coordinates of chart bars, when using relative horizontal positioning (0 to 150), and there is also a high-resolution version of this, available. Positioning is relative to the Chart Region itself. Here is an example of the Symbol Display:
https://www.sierrachart.com/image.php?Image=1725144997418.png
Make sure you are running an up-to-date version of Sierra Chart.
Date Time Of Last Edit: 2024-09-01 04:14:55
[2024-09-01 00:47:08]
Huh? You posted a reply with text, not a line. Question was about making a line extend to end of the chart not just the last bar.
[2024-09-01 00:57:30]
i think the issue is you're trying to combine absolute y with relative x, which doesn't seem possible
Date Time Of Last Edit: 2024-09-01 02:11:22
[2024-09-01 02:06:26]
using the previously linked EndIndex or extended DrawingType does what you want, i think..
#include "sierrachart.h"
SCDLLName("fill space line")
SCSFExport scsf_fill_space_line(SCStudyInterfaceRef sc) {
  if (sc.SetDefaults) {
    sc.AutoLoop = 0;
    sc.DisplayStudyName = 0;
    sc.GraphName = "fill space line";
    sc.GraphRegion = 0;
    sc.UpdateAlways = 1;
    return;
  double last_price = sc.GetLastPriceForTrading();
  double price_begin = last_price - (last_price * 0.0025);
  double price_end = last_price + (last_price * 0.0025);
  s_UseTool tool;
  tool.Clear();
  tool.AddMethod = UTAM_ADD_OR_ADJUST;
  tool.BeginIndex = sc.IndexOfFirstVisibleBar;
  tool.BeginValue = (float) price_begin;
  tool.Color = 0xff0080;
  tool.DrawingType = DRAWING_LINE;
  tool.EndIndex = sc.IndexOfLastVisibleBar + (int) sc.NumFillSpaceBars;
  tool.EndValue = (float) price_end;
  tool.LineWidth = 10;
  int& line = sc.GetPersistentIntFast(0);
  if (line != 0) tool.LineNumber = line;
  sc.UseTool(tool);
  line = tool.LineNumber;
Date Time Of Last Edit: 2024-09-01 02:15:45
imagefill_space_line.png / V - Attached On 2024-09-01 02:06:22 UTC - Size: 126.77 KB - 49 views
