Date/Time: Sat, 23 Nov 2024 09:21:13 +0000
Total Freeze of Computer
View Count: 162
[2024-08-31 14:34:13] |
vmitrader96 - Posts: 14 |
Hi When I use the Parallel Lines tool and change the line type it completely freezes my computer causing me to have to reset it. I've done it several times to confirm, happens every time. Just using the Parallel Lines is fine only happens when I change line type |
[2024-08-31 19:52:12] |
Sierra_Chart Engineering - Posts: 17145 |
What are you changing the line type to? Are you using OpenGL do you know? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-31 19:52:46
[2024-08-31 20:08:02] |
Hi, it happens when I change to dash or dot, haven't tried others. Not sure what OpenGL is sorry...
[2024-09-02 14:19:56] |
Check this setting: Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other) Let us know how it is set. Provide us the chart, following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart with the parallel lines, on that chart in the state just before you change the Line Style and then we will try to reproduce. Make sure to save the Chartbook (File >> Save) before attaching it. Also this is a very unusual problem. It is something that we do not hear about. Make sure your video driver is up-to-date and the operating system. If we cannot reproduce it must be system specific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-09-02 14:20:41
