Date/Time: Sat, 23 Nov 2024 09:21:58 +0000
How to change currency value per tick for Simulated Futures Trading account?
View Count: 183
[2024-08-28 17:59:32] |
Driss - Posts: 10 |
Hello SC, Is there a way to change the tick value for currency in Simulated Trading accounts? I made a new account (check out the screenshot), adjusted the balance, and changed the Global Symbol settings for NQ to have $0.23 per tick. While it shows up correctly in the Trade Activity, but the overall balance for the simulated account is still being reduced by the real $5 per tick. Any ideas? |
SierraChart_64_08_28_24_12_50.jpg / V - Attached On 2024-08-28 17:51:02 UTC - Size: 174.69 KB - 26 views Attachment Deleted. SierraChart_64_08_28_24_12_56.jpg / V - Attached On 2024-08-28 17:57:40 UTC - Size: 925.07 KB - 25 views |
[2024-08-28 19:03:06] |
You can not change the value that is used by the Trading Evaluator to determine your account value. Just like if you were live trading.
[2024-08-28 19:08:25] |
Driss - Posts: 10 |
Yeah, that make sense. Thanks!
Date Time Of Last Edit: 2024-08-28 19:08:36
