Date/Time: Sat, 23 Nov 2024 09:01:04 +0000
cfd 10usnote doesn't work
View Count: 147
[2024-08-28 17:02:55] |
User424220 - Posts: 10 |
https://www.sierrachart.com/image.php?Image=172486396713.png the gold line is the cfd 10usnote for the last two days it hasn't worked I've tried it on two different computers that are separate versions it stopped working on both I also loaded a chart using this symbol and there is no candle movement ????????? |
[2024-08-28 20:14:10] |
Sierra_Chart Engineering - Posts: 17145 |
We cannot help with this. We need to remove that symbol. Use the CBOT 10 year note futures. The symbol for this is: ZNU24-CBOT (September) ZNZ24-CBOT (December) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
