Date/Time: Sat, 23 Nov 2024 09:08:18 +0000
Using SC with Rithmic Pro
View Count: 106
[2024-08-28 06:26:40]
User276793 - Posts: 52
Hi I am having a problem when running SC with Rithmic data, When i try to open Rithmic Pro to track auto liquidation with prop firms It crashes or disconnects Sierra charts.
Someone in a chat said it was a setting i needed to change in SC.
Not sure what setting that might be. Any ideas?
thanks
[2024-08-28 13:40:50]
The interface that Rithmic built for Sierra Chart does not allow for multiple connections. So if you connect to that account through another means, then the connection to Sierra Chart will no longer function.
