Date/Time: Sat, 23 Nov 2024 08:54:28 +0000
QuoteBoard color
View Count: 118
[2024-08-27 20:35:13]
User731023 - Posts: 138
Can I change the color? Or even make it smaller?
Date Time Of Last Edit: 2024-08-27 20:36:07
image1mmmm.jpg / V - Attached On 2024-08-27 20:35:50 UTC - Size: 49 KB - 38 views
[2024-08-28 12:31:27]
Refer to the following:
Getting Quotes: Setting Colors
You can change the size of the window.
[2024-09-02 10:29:09]
Could not find in Graphic settings. I want to change exactly what I am pointing at.
The White boarder.
PS You can not change the size of that either. Sure, you
can drag the size of the entire quote board but not just the header.
Spending way to much time on this. Grrrrr
[2024-09-02 13:52:00]
Sierra_Chart Engineering - Posts: 17145
Yes of course, it is the dedicated intention of Microsoft to drive you mad. This is controlled by the operating system and it does not let you control that color because they are damn evil criminals. And we are being too nice here. Microsoft is evil.
If there is any color in Sierra Chart, or other graphics item, that you want to change, and it is within our control, then let us know and we will add us separate setting for that.
Update: We have been told that in Windows 10 you can control the title bar color by editing the registry.
Date Time Of Last Edit: 2024-09-02 13:57:59
