Date/Time: Sat, 23 Nov 2024 08:58:57 +0000
latency on nasdaq total view problem
View Count: 142
[2024-08-27 19:11:03]
hakim belhassani - Posts: 5
I have a latency problem on my nasdaq data of about 2 seconds and more than 5 seconds on nasdaq total view on the US session and more on the European session (as a reminder I downloaded the latest version of sierra chart)
as I am a scalper I cannot execute my entries and exits precisely
please solve the problem or give me a solution.
thank you.
[2024-08-27 19:12:57]
Refer to the following:
Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds
[2024-08-28 09:34:21]
THE PROBLEM STILL REMAIN, EVEN USING HIGH COMPRESSION AND REMOTE BUFFER DELAYED SEND TIME IN MILLISECONDE OF 5000 MIL SEC
[2024-08-28 14:14:15]
Sierra_Chart Engineering - Posts: 17145
There is no real latency problem. The NASDAQ TotalView data feed is fine and we are sure it is fine in your particular case as well.
What you are observing is simply less trading activity, with NASDAQ TotalView versus the the consolidated tape feed. When there is less trading, you are going to see less frequent updates.
So what you need to use instead is the US Consolidated Tape data feed which we have:
US Stock/Equities Consolidated Tape Data Feed
Date Time Of Last Edit: 2024-08-28 14:16:32
