Date/Time: Sat, 23 Nov 2024 09:08:29 +0000
Charts / NEXT To Each Other
View Count: 101
[2024-08-27 14:39:54] |
User38606 - Posts: 106 |
Hi, I have 2 chartbooks (separate) with its own spreadsheet studies attached. I want to have one as 5 min chart and another as 15 min chart side by side so I can watch them on my screen rather than switching between 2 chartbooks all the time. How can I do that? How can I arrange those 2 charts out of those 2 separate chartbooks to stand next to each other. Lost there....tried everything. Thank you for help.
[2024-08-27 16:43:45] |
In order to be able to view a chart from a chartbook that is not the active chartbook, you need to set the option for "Window >> Window Always Visible". Refer to the following: Window, CB and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
