Date/Time: Sat, 23 Nov 2024 08:41:42 +0000
how exactly do you determine the spread...
View Count: 124
[2024-08-27 13:18:26] |
User849502 - Posts: 345 |
John, I have a question I hope you can educate me on. For CL I have my TPO chart set to 'continuous...VOLUME based roll, back adjusted'. When the yellow pop-up appears on my chart it's time to roll I go to the CME website and check the live volume to make sure the second month is indeed more volume than the first. If it isn't, it always is within a few hours. No issue there. My question is when SC rolls Sept into Oct there is the issue of what you assign as the spread value. How and when do you determine what you use for the spread? Going back to my looking at the CME site I notice that on the day of the roll, the spread moves a few ticks each way. So how does SC determine what it uses? I really really appreciate any help you could give me. Thank you so much in advance. Karen |
[2024-08-27 15:56:21] |
We are not sure what you mean by the "Spread". Are you referring to the amount of the back-adjustment? If you are referring to the back-adjustment, then refer to the following: Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
