Date/Time: Sat, 23 Nov 2024 09:08:30 +0000
Drawing Position Order Lines
View Count: 124
[2024-08-27 13:03:23]
awakef - Posts: 66
Hi there's a option that I can select to draw the order lines above objects that are in the chart?
[2024-08-27 15:46:43]
In general, the position/order lines are drawn above other items. The one caveat to this are drawings, where the drawings may be drawn above the position/order line if the drawings are set to be displayed above other items. Therefore, you would need to change how the drawings are being displayed in order to change this behavior. Refer to the following and the setting below it:
Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
[2024-08-27 17:23:13]
awakef - Posts: 66
Thanks John like always 👍.
Btw a different question do you know another broker besides CQG that provide bid, ask data?
[2024-08-27 17:48:48]
You are getting your data for the CME Group from our Denali Exchange Data Feed. So it does not matter what broker you use, as you will get the same data.
If you are asking something else, then please give us more information.
[2024-08-27 17:54:52]
awakef - Posts: 66
Im looking for ICE bid, ask data
[2024-08-27 18:01:41]
If you are wanting to trade the ICE and get the data, then CQG is your best bet. But you could also try brokers that support Rithmic, or Interactive Brokers. Those the ones we work with.
If you just want the data and are not trading directly from Sierra Chart, then you can try DTN IQ Feed. Refer to the following:
DTN IQ Feed Data Service
[2024-08-27 18:07:02]
awakef - Posts: 66
Thanks John 👍👍👍
