Date/Time: Sat, 23 Nov 2024 08:32:10 +0000
new laptop
View Count: 90
[2024-08-27 06:39:50] |
Crtfyd - Posts: 278 |
I got a new laptop with Win11. My old one was Win10. I downloaded the latest version off the website to the new Laptop. (vs 2670) I backed up the whole Sierra Charts file to a thumb drive from the old laptop. I dropped the "Data" file from the backup to the new laptop data file. Of Course it said "replaced existing files", I said yes as I figured it would be the same file as my old laptop, except with maybe some Win11 differences. I opened a Chartbook on the new laptop which had the other laptops "Current Cht", but only one window opened with a lot missing. Nothing like all my settings,etc. Whats the best way to transfer to my new laptop? Just erase the whole SC file from my new laptop, then paste the whole file from my old laptop? Because the old was Win10 and the new Win11 would that screw things up?? Thx |
[2024-08-27 13:04:10] |
Sierra_Chart Engineering - Posts: 17145 |
Follow through the instructions here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
