Date/Time: Sat, 23 Nov 2024 08:33:01 +0000
Change Text Tool Settings on Chart - Doesn't always apply changes.
View Count: 90
[2024-08-26 23:05:42] |
User92573 - Posts: 530 |
Dear Support Board, Is anyone having the same issues or have I simply missed something. 1 - Select abc Text Tool. 2 - Enter Text. 3 - Reselect as decided to change font size and color. 4 - Right Click Chart Drawing Properties. 5 - Select Font Color, Font and Font Size. 6 - Apply All (not actually req.) 7 - Select OK Sounds simple .... But the text does not always change. Sometimes it updates for me and sometimes it does not. What am I missing? Syntax, order of operations? Snapshots attached and on that occasion it didn't work. Any help appreciated. Many thanks. Date Time Of Last Edit: 2024-08-26 23:11:26
Text Settings 001.png / V - Attached On 2024-08-26 23:04:31 UTC - Size: 323.3 KB - 25 views |
[2024-08-27 02:25:53] |
Sierra_Chart Engineering - Posts: 17145 |
This has already been resolved. Update Sierra Chart to the latest version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
