Date/Time: Sat, 23 Nov 2024 12:54:45 +0000
Consolidated Tape for US Equities (SIP Data)
View Count: 106
[2024-08-26 21:10:24] |
User265996 - Posts: 1 |
i'm trying to find out what data I'd need to build the market breadth ration bubbles for NYSE / Nasdaq I believe to create the market breadth, the total ädvances and declines volume data from both NYSE and NASDAQ is required. The ratio between both sides of the market can then be calculated and moved to the main chart as "text display for study from chart". here's another board trying to find a solution: Market Breadth Bubbles There are other support boards looking to find a way too - I just haven't found the right one yet (perhaps). Date Time Of Last Edit: 2024-08-26 21:11:13
[2024-08-26 21:36:47] |
The Advance/Decline volumes for NYSE and NASDAQ are available as part of our Market Statistics data. This data is available to you already with no cost. Refer to the following: Sierra Chart Market Statistics For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
