Date/Time: Sat, 23 Nov 2024 12:31:40 +0000
I would like a sierra chart in all black tones
View Count: 121
[2024-08-26 20:50:47] |
User959382 - Posts: 10 |
Hi, I took the image I sent from the web, I would like a sierra chart in all black tones, not white like now. Can it be done? Or can the colors be changed, as I see on the web, one piece at a time? And how? A thousand thanks |
Screenshot_2024_08_22-2.png / V - Attached On 2024-08-26 20:50:44 UTC - Size: 308.55 KB - 45 views |
[2024-08-26 21:25:26] |
You have to change the particular colors that you want, one at a time. Refer to the following: Graphics Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
