Date/Time: Sat, 23 Nov 2024 09:00:41 +0000
Flatten Simulated Position
View Count: 135
[2024-08-26 19:52:17]
User475815 - Posts: 3
I'm not able to Flatten my open Position in my Instance.
Can you gave me some advice? I don't have the Denali Feed activated, is that a possible reason?
Kind Regards
T
[2024-08-26 21:06:45]
What exactly is occurring when you try to flatten? How are you flattening? Are you able to see the open position in a chart, and are you flattening from the same chart?
Using the Delayed Streaming Data with the Built-in Simulation Mode has no affect on the ability to flatten or not. It is definitely not related to this.
[2024-08-27 15:21:53]
Nothing is occurring...
At 9:30 there is something like a lock. I don't see anything.
I Flatten my Positions from the Trade Window which is attached to the Chart.
Today I could close my Trades...
I thought at first the session time settings have an effect on it...
I will continue to observe this behavior. If this Problem does not vanished or comes back I will do a reinstallation.
Thanks for your effort.
Do you have some knowledge about the DTC Protocol. I have one question which i would like to ask you directly.
[2024-08-27 16:50:35]
Do NOT reinstall the software. There is never a reason to do this. You may need to update occasionally, and you should, but never re-install. Refer to the following regarding updating:
If you do see the problem again, you will want to look in your "Trade >> Trade Service Log" and see if there is any information in there on why you are not able to flatten.
