Date/Time: Sat, 23 Nov 2024 11:45:39 +0000
SymbolData is null
View Count: 91
[2024-08-26 15:17:41] |
User357032 - Posts: 1 |
Hello, I have downloaded and installed SC software and currently with the trial package. I am trying to enter a symbol in the quoteboard but it says the following: "SymbolData is null until symbol is known to data feed". Any idea why I cannot introduce a symbol? I am connected to the Data Feed. Thanks. |
[2024-08-26 19:39:06] |
You can only access data for certain symbols while on a trial. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
