Date/Time: Sat, 23 Nov 2024 12:37:04 +0000
All charts on chartbook frozen
View Count: 84
[2024-08-26 15:11:50]
sabbers - Posts: 21
I made a copy of a chartbook. Upon opening the copied chartbook all charts are frozen.
The original chartbook is working fine.
How to fix this?
Thx!
Sabbers
[2024-08-26 19:38:15]
Are the symbols in the copied chartbook correct? Was there a change to the service being used and the other chartbook was not updated? If so, then select "Edit >> Translate Symbols to Current Service" in order to update the symbols for the chartbook that is not working. Refer to the following:
Edit Menu: Edit >> Translate Symbols To Current Service
If not the above, then we would need to see your Message Log for the chartbook that is not working by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chartbook you have an issue with through "File >> Open Chartbook".
