Date/Time: Sat, 23 Nov 2024 12:56:47 +0000
Two Price Ladders
View Count: 93
[2024-08-26 14:27:26] |
User131975 - Posts: 78 |
Hello, I have two Price Ladders, one with the MES and another with the ES. Is it possible that I can activate the simulation mode on only one price ladder and still trade normally with the other one? I would like to learn scalping and therefore I need this. Thank you! |
[2024-08-26 19:26:29] |
The only way to do this would be to use either a Sub-Instance or a second installation of Sierra Chart. If you use a Sub-Instance, then you would need to set that Sub-Instance to be the one in Simulation Mode and then have the main installation trade live. Otherwise, if the main instance is in Simulation Mode, then essentially both instances are in Simulation mode. Refer to the following: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method) The instructions to install a second Sierra Chart (if you choose this method) is at the following link: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
