Date/Time: Sat, 23 Nov 2024 12:55:14 +0000
Saving Text to Lines/Rays
View Count: 11735
[2024-08-26 12:58:32]
User163966 - Posts: 4
Copy Config Label to Text - I do not see this option on the Lines / rays Drawing Properties forms. I can not get text to save. What am I missing?
[2024-08-26 19:08:09]
It will not be on the "Drawing Property" as the copy of the text from the Configuration Name to the drawing is done when a drawing is first drawn. Therefore, this option is only shown in the "Tool Configuration" options.
But we, do see that it is not present for the Ray. It is there for Line. We will have to check into the Ray option to see if this had been there previously and then not copied over to the new format, or if it was never there.
