Date/Time: Sat, 23 Nov 2024 09:07:44 +0000
Charts Not Displaying Correctly
View Count: 157
[2024-08-26 08:39:31]
User160486 - Posts: 40
When I change the time frame within the same chart, all the candles and indicators, etc get scrunched together (see image). When I change the chart symbol
The same thing happens. I have to constantly close the program and open it. I tried redownloading the software. Nothing helps. Please help.
Private File
[2024-08-26 09:11:24]
Here is a screenshot of my problem.
attachmentIMG_7613.jpeg - Attached On 2024-08-26 09:11:00 UTC - Size: 2.62 MB - 32 views
[2024-08-26 19:02:40]
There is a study causing the scaling issue. Hide them one by one until you find the culprit:
Chart Studies: Settings and Inputs Tab >> Hide Study
Also refer to:
Chart Scale and Scale Adjusting: Resetting the Scale
[2024-08-26 19:09:13]
Does it really just happen overnight? I haven’t changed anything in months and all of a sudden I have this problem. If it only happens when I try to change the chart symbol, is it still a study causing the scaling issue? And why did it randomly just happen?
[2024-08-26 21:01:45]
We can not say. But when a chart gets compressed like what you see, it is due to a study that is has data that is much wider than the other information you are trying to display. Refer to the following:
Chart Studies: Preventing Study From Compressing Main Price Graph
[2024-08-27 09:39:21]
Thank you very much. That fixed my problem. Have a nice day.
