Date/Time: Sat, 23 Nov 2024 12:51:42 +0000
Can't connect
View Count: 80
[2024-08-25 17:59:52] |
Tin43 - Posts: 90 |
Hope someone can help: 2024-08-25 13:58:43.183 | Trading Evaluator - Delayed | Connecting to the server tradesimulation1.sierracharts.com. Port 11095 2024-08-25 13:58:43.184 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-08-25 13:58:43.184 | DTC Client socket (1) | New receive buffer size: 0 2024-08-25 13:58:43.184 | DTC Client socket (1) | Connecting to IP: 69.39.70.243. 2024-08-25 13:58:45.863 | DTC Client socket (1) | Connect event error. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. * 2024-08-25 13:58:45.863 | DTC Client socket (1) | CloseSocket call. 2024-08-25 13:58:45.863 | Trading Evaluator - Delayed | Failed connections: 12 2024-08-25 13:58:45.863 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2024-08-25 13:58:45.863 | Select 'File >> Disconnect' to prevent further connection attempts. 2024-08-25 13:58:45.863 | DTC Client socket (1) | Closed. 2024-08-25 13:58:45.870 | DTC Client socket (0) | CloseSocket call. 2024-08-25 13:58:45.870 | Trading Evaluator - Delayed | Disconnected. 2024-08-25 13:58:45.870 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. I get this on loop. |
[2024-08-25 18:49:57] |
Sierra_Chart Engineering - Posts: 17145 |
This is now resolved.
