Date/Time: Sat, 23 Nov 2024 12:42:33 +0000
High/Low for Time Period - Extended
View Count: 135
[2024-08-25 12:38:58]
User528002 - Posts: 13
Good morning.
I am using the "High/Low for Time Period - Extended" Study to draw a line for the Half Hour Opening Range and also for the Pre-Session (overnight) High/Low.
Currently the study shows these highs and lows at all times, even if they are far removed from the price action. This becomes a problem when the price action is far removed from the highs and lows as it "squishes" the price action. Is there a setting so that the highs and lows are only shown if they are in proximity to the price action?
I notice that with the Pivot Point Study, for instance, it does not insist on showing all the support and resistance lines on the chart and I would like the same for the High/Low Study.
Many thanks.
[2024-08-25 13:29:30]
Sawtooth - Posts: 4118
On the 'Settings and Inputs' tab, set the Scale to 'Same as Region'.
