Date/Time: Sat, 23 Nov 2024 12:17:02 +0000
Study Summary: Copy or Export data
View Count: 151
[2024-08-25 10:09:04] |
User551647 - Posts: 22 |
Dear Sierra Chart Team, I have charts books with one chart for each stock of an index where I calculate indicators like for example the relative strength (current close/sma(x-periods). I am using the Study Summary to list the indicators values - here the relative strength (RSL). You can see my set-up in the attached screenshot. https://www.sierrachart.com/image.php?Image=1724580325595.png Is there any way to copy or export the text/data from the Study Summary to use it in another Software like EXCEL. This does not need to be automatic but just select all and copy to paste it then to another software or the option to export the Study Summary table as .csv. Thank you very much in advance. |
[2024-08-26 17:56:18] |
There is not a way to directly export the information in the Study Summary window. You can access the information through a custom study, so you could then get the data through that study. Refer to the following: sc.GetStudySummaryCellAsDouble() https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
